tray heaters
  • Mark Bbb
    • Jun 2012
    • 1662
    tray heaters
    Hello there,
    What is your experience with tray heaters, does it help?
    Situation: mp2500 in office without carpet or curtans, windows closed, no ventilation.
    Tray 3 is the "switch over tray" when tray 1 is out of paper. Tray 3 jams frequently, i have replaced the paper feed rol and frict.path, put an extra curl in the bottom lift spring at the back... but it keeps on jamming.
    Will a tray heater fix the problem?
    Thank you kindly for your reply.
    Greetings,
    Mark
  • andy227
    • Jan 2013
    • 219
    Re: tray heaters
    Mark, are you seeing evidence of damp paper issue, such as curling or banana shaped copies when fed out ? If damp paper the issue you should see this. It would be the same problem from both trays, not just number two. Try some fresh paper out of the box and see what happens. Duplex would normally make it worse. Tray heaters I suppose would not hurt, although I haven't tried them myself, but establish first what the issue is.
    • Zaxxon
      • 608
      Re: tray heaters
      Tray heaters use alot of power, please check this before offering this to your clients.
      Please start you post with brand, model, problem.
      • Mark Bbb
        • Jun 2012
        • 1662
        • sandmanmac
          • 3981
          Re: tray heaters
          You have a non feed paper jam problem, yet I see no mention of you checking or changing the paper feed clutch ?
            • 37533
            Re: tray heaters
            I do not think you have told us what the jam code listed in the SMC report is. You might be looking at a dirty sensor jam.
            • andy227
              • Jan 2013
              • 219
              Re: tray heaters
              Maybe so, but, if it proves to solve the problem then its the customer's problem. Jams and call out every day vs no jam and some extra use of power, which to choose ?
              Good point, but maybe Mark can tell us exactly where the paper is jamming (not feeding out of tray at all, definately clutch, half out, reaching the fuser ?) and how frequent (every copy, one in three ?)
              Has installing the heater made any difference ?
              Are you are taking him to court or he is taking you to court ? Some customers will insist on using the cheapest crappiest paper they can get, combined with some moisture, and a small machine like an mp2500 and its a bad combination. If you still suspect the paper, go in with some really decent paper like 90gsm Navigator and prove it to him.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Re: tray heaters
                A cheaper option that i use with success is to place a couple of the large silicon bead bags that come in the machine boxes at run up.
                Place them in the tray (on the other side of the fence of course).
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Re: tray heaters
                  No, i have not, customar was complaining in the second year the machine was installed, so the clutch was rather new...
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Re: tray heaters
                    I have Cleaned it very well. Paper is jamming the first centimeters or don't leave at all.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      Re: tray heaters
                      We are taking him to court, saddly, that is the policy here with no payments. The paper is "discovery" a very good paper, i gess. After i installed the heater, it was still jaming, i went back and saw that the paper size sensor at the back of the machine was broken (the atcuator was loosen). I fixed it and problem was solved. You might say that was the problem, i agree, but i also now that - when it jams a lot - customar is taking it out on the machine by closing the tray very brutaly after a jam and break al kind of parts...
                      • andy227
                        • Jan 2013
                        • 219
                        Re: tray heaters
                        Yep, that would definately cause paper jams out of the tray. Good that you fixed it. As for 'discovery' paper, I never recommend it, especially where there are damp issues. Its a thinner paper at 75gsm which makes it more vulnerable to damp and curling.
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          Re: tray heaters
                          Nevertheless, i want to know what is your experience with tray heaters...
                          Good, bad, thank you for your reply!
                          Waiting...
                          Greetings,
                          Mark
