Ricoh 1107 how to print without Fiery
  • bojans
    • 1313
    #16
    Re: Ricoh 1107 how to print without Fiery
    Originally posted by Sashko
    Set SP5-193 to "0", plug the network cable to Gigabit Ethernet, setup the network adapter and...
    Thank you Sashko,
    but changing this parameter, nothing happened.
    • Sashko
      • Oct 2009
      • 110
      #17
      Originally posted by bojans
      Thank you Sashko,
      Bojans, I think you must order printer/scanner SD card.
      See recommendations from slimslob in previous reply.
      • jmhashmi
        Technical Supervisor
        • May 2009
        • 62
        #18
        The only solution is Printer/Scanner kit.
        • bojans
          • 1313
          #19
          Thank you all for help,
          Where can I find this kit? can't find it on internet, only on aliexpress.
          Anyone knows supplier in Europe?
          • Sashko
            • Oct 2009
            • 110
            #20
            Ask ricoh-europe.com or search.
            As example Vegos : main
              • 37533
              #21
              You must not be searching correctly.
              Ricoh Printer / Scanner 1357 Kit
              • bojans
                • 1313
                #22
                Thank you very much for all help and info,
                I got printer/scanner kit and ps3 option today.
                Best Regards
