MPC4503 sc 549-04
  • greyfox
    • May 2010
    • 20
    MPC4503 sc 549-04
    Hi Guys,
    While changing fuser sleeve and pressure roller for 2 units of MPC4503
    I encounter SC549-04 on 1unit and the other machine works fine.
    I have read the manual and it says:
    549-04 D Shield Operation Error Detection
    During HP detection operation, HP detection fails 3 times consecutively.
    • Motor defective
    • Sensor defective
    • Sensor actuator/feeler modification/defective
    • Shield modification/defective
    • Replace the motor
    • Replace the HP sensor
    • Replace the fusing unit
    any suggestion guys? I appreciate your help....
    thanks in advance....
    cheers
  • LNorris
    • Sep 2008
    • 645
    Re: MPC4503 sc 549-04
    do a search on this forum, I believe that code means you need to install that fuse that comes with the fusing sleeve.
    • copier tech
      • 8192
      This happened to me on the training course!
      I took out the wrong screw & the sheild shutter arm was out of position. It should move freely by hand from front to back. Basically check this area, you may have accidentally snapped it off.
