Double image (MP CW2200)
  • sharpmind
    • Sep 2009
    • 478
    Guys, how can i rectify this kind of printing problem? (see attached photo).The image is blurred only in the left side(see the encircled image). Print head cleaning does not solve the problem. The machine is still new.Any ideas? Thank you. print.jpg
  • imihm
    • Feb 2014
    • 77
    Re: Double image (MP CW2200)
    Originally posted by sharpmind
    Guys, how can i rectify this kind of printing problem? (see attached photo).The image is blurred only in the left side(see the encircled image). Print head cleaning does not solve the problem. The machine is still new.Any ideas? Thank you. [ATTACH=CONFIG]31060[/ATTACH]
    Hi there....
    Identify which color is the problem and run head flushing......
    thanks
    • jeff33
      • Aug 2009
      • 61
      I had a similar problem and I cleared the print memory it took care of the problem. Its in the 5s in SP mode
        • 37059
        SP 5801-008 Printer Application Memory and SP 5801-004 Image Memory Handler.
        • subaro
          • Oct 2010
          • 1274
          Do printhead flush and then run printhead test. [page 163] [ read your manual, it is there to assist and guide you. ]
          page 167 of the user manual
          Auto Adjust Head Position
          If bidirectional printing produces misaligned verticals or blurred colors, printing the test pattern will re-
          calibrate the machine. The test pattern differs depending on the print quality.
          • ennadhe
            • Apr 2015
            • 7
            what if its not happening all the time and not on a specific area. is this fix will do?
