Ricoh Aficio MP301 with SC672
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Hi guys
    Got this little machine Ricoh MP-301 showing SC672
    As per the manual I checked the Controller board and Dimms but still the same
    The machine warms up and produces some (5, 6 copies) but no more and then stalls.
    Any other idea is welcomed.
    Thanks,
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • jeff33
    • Aug 2009
    • 61
    Re: Ricoh Aficio MP301 with SC672
    HDD if it has one
    • rapidocument
      Multibrands Tech
      • Jul 2012
      • 381
      This model doesn't have HDD.
      • Slakkie4x2
        • Feb 2011
        • 27
        Faxboard?
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          Check the connectors & cables from controller/LCD-screen, and very important. a complete fw-update.
          Greetings...
          • copier tech
            • 8172
            I had the exact same fault it was the controller board.
            Check to see if theres other sc errors in the history, mine had sc802 I believe
            • bob marley
              • Jan 2012
              • 1339
              Check the condition of the operation panel and its connector
              Live for yourself and you will live in vain. Live for others, and you will live again
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                It's an option, and required for certain functions.
                • dpoutz
                  • May 2011
                  • 78
                  Originally posted by Zeldaman
                  Hi there!
                  Greetings...
                  I'm having same issue the only thing I haven't t ried is op-panel and harnesses. I found part number for op-panel and usb harness but not the grey wiring harness that goes to BICU. I scoured the parts manual. did any of you order both harnesses? if so do you know the numbers? Thanks
                  • logrady2331
                    • Feb 2011
                    • 301
                    We've had two of them do the same thing and both times replacing the fax board took care of it. SC672's can be very tricky to troubleshoot. Take the fax out of it and see if it still codes. My guess is it won't. Hope this helps.
                    • apump
                      • Mar 2009
                      • 160
                      I had to replace the dim on the controller for 672
                      • Lagonda
                        • Aug 2008
                        • 1649
                        Harness part numbers are on the point to point circuit diagram but I doubt very much if that is the problem. My experience is it that if you have unplugged the HDD and the fax and it still has the problem you are looking at a new ops panel or controller.
                        • dpoutz
                          • May 2011
                          • 78
                          The harness parts numbers are on the point to point diagram. Ok
                          • Imprestik
                            • Aug 2012
                            • 297
                            I have had a bucket load of these and the issue has been the main drive motor shorting out the controller.
                            • TonerMunkeh
                              Professional Moron
                              • 3865
                              Imprestik have you had any do this recently?
                              Hit it.
