MPC2003 printing Dark
  • Leebs14
    • Feb 2014
    • 457
    I have a two week old machine which has less than 1000 prints on it which is printing photos really dark. Every print comes out dark like a miserable winters day when the photo on the screen is a bright sunny day.
    Before you think it's screen calibration or RGB to CMYK isn't the same and it's not a WYSIWYG printer etc etc the same photos print perfectly on their existing MPC2551.
    I've calibrated it but haven't touched anything else as everything is as per a standard machine.
    As a workaround I've created a profile in the print driver with the brightness increased by 50%.
    Anyone seen this, using PCL6 driver
    • 37550
    Re: MPC2003 printing Dark
    Samples please.
    • Zeldaman
      • Mar 2011
      • 946
      • slot
        • Jul 2008
        • 341
        hi zeldaman I have an mpc2503 and some mpc3003 that all the customers do is say the pic that they print out are to dark I have tried the files on other copier like mpc 2800 3501 and they all print great I have also tried the adj the bit swt to get the copier better as per a bulletin from ricoh but it made very little change these copiers just print very poor it seems but then they are marketed as business copiers I would love to see an answer from ricoh.
          • 37550
          One thing I had read concerning Metis line is that a full Auto Color Calibration should be ran not only prior to install but also after every firmware update. I don't know if this will help, but my experience with complaints of light copies has been that either there are no values in the ACC or it has been a long time since it was run. Cleaning the optics and running ACC usually takes care of the light copies.
          • Leebs14
            • Feb 2014
            • 457
            It's dark prints not light prints. I'll try and upload some samples later
              • 37550
              If the dark print is due to the print controller in the machine, the color gray scale will be printed darker than normal in the printer portion of the ACC. The scan portion will then detect that and adjust to compensate, assuming that the scanner has already been calibrated in the copy ACC.
              • Leebs14
                • Feb 2014
                • 457
                Image-001.jpgImage-000.jpgsamples of the dark print attached. the MPC2551 prints so much better than their 2 week old brand new MPC2003??
                  • 37550
                  Have you tried the PCL5C driver?
                  • Leebs14
                    • Feb 2014
                    • 457
                    No I didn't, I'll remember to try it when I go back
                    • Seriousfab
                      • Feb 2012
                      • 10
                      Hi, how did you solve this ?
                      • Seriousfab
                        • Feb 2012
                        • 10
                        Hi, have you find the solution ?
                        • Seriousfab
                          • Feb 2012
                          • 10
                          Problem "Solved", switched MP C 2003 with MP C 3002 and no more dark problem...
                          • Gift
                            • Mar 2011
                            • 2459
                            Driver advanced setting (I think somewhere under the quality options) > color profile - > set everything to "color laser printer simulation" and compare the results
                            • Seriousfab
                              • Feb 2012
                              • 10
                              Well we tried all these settings and our conclusion is that the controller is weak, the image treatment is bad...
