Horizontal Lines pro 906ex
  • ali.alhaj
    • Mar 2013
    • 34
    [CQ] Horizontal Lines pro 906ex
    I have problem with pro 906ex when printing from PC after 500 to 1000 the machine print horizontal line.
    My procedure :
    1- replace LD
    2- replace POLYGON
    3- NEW firmware engine+system.
    4- Replace Controller Box
    5- Replace IOB board + BCU board.
    6- OPU board
    7- Replace Front Switches.
    The Problem is still.
    Can any body solve this problem.
    thanks.
    • 37052
    Re: Horizontal Lines pro 906ex
    Are the lines parallel to or across the direction of paper travel? Please provide a scan of a sample.
    • ali.alhaj
      • Mar 2013
      • 34
      Hi
      the file in the attachment .
        • 37052
        Originally posted by ali.alhaj
        Hi
        If the paper was fed long edge first, I would say that it is time to rebuild the PCU cleaning unit, both coronas and possibly replace the drum.
        • hossam
          • Aug 2010
          • 70
          hey there,
          i have the same problem, have you found the solution for this problem?
          thanks
