Ricoh MP4002 resets
    • 30393
    Ricoh MP4002 resets
    Looking to find out what resets to run in the SP mode to clear out data , network information , address book and settings back to defaults.
    Thanks in advance
    • 37556
    Re: Ricoh MP4002 resets
    SP 5801-XXX where XXX is:
    006 Copier Application
    007 FAX Application
    008 Printer Application
    009 Scanner Application
    010 Web Services
    011 NCS (Network Settings)
    Do not do 001 or 002 unless you have the birth certificate for the machine as all machine specific settings for the Engine will be cleared.
    SP 5846-050 Initialize All Addr book Clears everything (including users codes) in the directory information managed by UCS. However, the accounts and passwords of the system administrators are not deleted.
    You may also want to format or replace the HDD.
    Counters are not cleared and cannot be cleared by any SP code.
