PRO 8100 what do you think ?
  • monkees
    • Jan 2011
    • 40
    Hey guys ! I have pro 8100 in assistance
    have many problems with paper jams, strange codes, jam sorter ecc
    this is terrible machine ?
    I regret the PRO907
  • anothertech
    • 1771
    Re: PRO 8100 what do you think ?
    They work ok in print shops with very few users, but there are problems when used as walk up machines. Schools where all of the teachers use them, forget it!
    • Iowatech
      Not a service manager
      • 3930
      I have only a little experience with the Pro line. Still, they are "production" machines. As such, they require properly trained operators. If you can do that, you should be good to go. If not, something else will happen.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Wow!
        Are the Monkees still popular in Italy?
        Or are you a hold out (like me)?
        They were my favorite back in the day, although I was all of 10 years old.
        • monkees
          • Jan 2011
          • 40
          KenB The Monkees they were famous when I was born - I like the sixties music
          PRO 8100 On the site Ricoh there are 14 pages of technical information
          great copy works has big problems
          I wanted to know if I have problems just me
          • jfbar1
            • Oct 2008
            • 53
            The biggest thing about this series of machines is, if you are a primarily a black/white (mp6000,pro906 etc) tech, you will be LOST on this machine. It is a Taurus (c651EX) based engine with a Aegis (c901) drum/dev unit.
            Yes, there are ALOT of tech bulletins on it as it is a clean sheet design. Firmware is key as well as any (factory based) mods that are published.
            My first (and only) unit in the field put a million on it within 8 months. To date (so I'm told as I moved on), it has nearly 4 mil. It was installed 6/2014, so little over 2 years.
            When CQ fades (as well as SC401), clean out the developer doctor blade (I used business card, DO NOT TOUCH THE SCREWS holding it on).
            When you get jam codes (usually J050) clean out the reg roller dust mylar and wipe off the CIS. Then MAKE SURE you have the right paper type (even color) programmed into the settings.
            Carry several spare Lube bars, as when the machine detects end, IT WILL SHUT DOWN. The first few bulletins (never liked saying PUB's-LOL), and firmware updates, addressed the premature wear. Make sure the tension spring is attached to each other (NOT attached to the mounting post).
            Good luck on your mission
            • anothertech
              • 1771
              The biggest problem we see here is that the machines get a jam in the #1 feed unit in where the customers can't get to it. This downs the entire machine. If Ricoh would write the firmware to just disable the #1 tray when jammed, the customers could go on using the machine, running out of the other trays.
              • monkees
                • Jan 2011
                • 40
                Thanks for the replies
                the problems I see are the same
                I have a big problem with j031, even after replacing the transfer, and sheltered together with the specialist, you cannot solve
                I keep you updated ...
                  • 37558
                  Have you retrieved the debug log to see if it has any helpful information? You sometimes have to send it to tech support for analysis. Are there any other symptom than J031?
                  I have seen jam codes generated by actual problems elsewhere in the machine that would seem totally unrelated to the jam. As an example, I had a Pro 1357EX that was giving finisher jogger rams. While running the machine to see if I could catch which jogger it was I noticed that the copies were fading. Deciding that that was a greater problem than the jamming, I started trouble shooting it. I found that the motor that drives the toner dispensing shaft in the toner hopper was shorted. After replacing the motor, the finisher jamming as gone. According t tech support, the jam code was actually a catchall code. It meant that the was an undetermined problem while a jogger fence was moving. Apparently, when the machine tried to add toner, the shorted motor as causing a dip in one if the power supply voltages that was being picked up by the finisher.
                  • Tonerbomb
                    AutoMajical Resolutionist
                    • Feb 2005
                    • 2589
                    The biggest gotcha is the update from version 1 frimwar to version 2 frimwar, especially if you have a fiery on the machine. Otherwise with a good operator the Barons will run! Got 2 less than a year old over 1.5 mill each, true production environment. they can run well past PM, but if you do this when they have issues do all the pm stuff and their off and running again......................... Always run any color paper set as color paper 2, there is a bulletin for this about jams on color paper..............
                    Mystic Crystal Revelations
                    • monkees
                      • Jan 2011
                      • 40
                      On PRO 907 to me had happened with cut cords of the synchronization engine
                      problems you listed we had cases on other machines
                      with the problem J031 I have to go see her for the second time with the technician ricoh ita before we have not solved
                      We update
