Really Dissapointment using Gestetner MP 2000 L2
  • Zaxxon
    • 608
    Re: Really Dissapointment using Gestetner MP 2000 L2
    Originally posted by ruben
    The MP 2000 were good machines, in fact, the newer entry-level B&W are mostly built off this model with some increased processing power and memory capacity. The fusers are easy to rebuild, have only a few issues with stripper pressure over time, and the UFRs can degrade with extensive above PM usage. The drum is easy to rebuild and does last past PM. We always replace drum, cleaning blade, charge, and dev together. Sometimes the dev gears do wear down, requiring a complete dev unit replacement. We used to have a lot of these machines out on construction sites, back in the day, until everyone wanted colour. Keep it clean, and replace at or just past PM, and it wil last for years.
    The machine is fine But not for at copier center, 1000 copies will take almost an hour...
    Please start you post with brand, model, problem.
    • sandmanmac
      • 3981
      Exactly! So even the smallest amount of common sense should have told the poster that the machine wouldn't be practical in his environment.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        Ahhhh this thread brings back memories of aaB1.............................................. .......
        Mystic Crystal Revelations
        • 813200217
          • Oct 2014
          • 51
          #19
          and you still recommend this machines to copier centre business?
          • subaro
            • Oct 2010
            • 1274
            #20
            come on mister. the guy has not said so, it is for you to decide. It does not matter if the machine can do 5 copies per minute cpm. You are supposed to arrange for a demo of the machine and see if it can do what you want. Copy centers are not all the same and your volume may be entirely different from another customer. I hope when you go to buy a car you test drive it before you make the purchase.
            There are many other things to consider when you purchase or lease a copier. If you are not sure what you getting into, then seek help and read the fine prints before you sign.
            a simple search on the internet brings up a lot of ideas. just google this below and see some results.
            how to buy a copier
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              #21
              We wont recommend, but you are questioning the mind of a SALES?
              That road is dark and narrow, do not tread.
              I'm sure the service guys who looked after it shares the same sentiment.
              You survived, take pride in that.
              Idling colour developers are not healthy developers.
              • rthonpm
                • Aug 2007
                • 2857
                #22
                No, he's saying that these machines were decent boxes in the CORRECT environment. A copy centre is obviously the WRONG environment for a 20 ppm machine. It's been nearly twenty years since I worked in a copy centre, but even then the slowest machines we had were 30 ppm colour machines. For pure black and white, anything under 50 ppm is useless in that kind of environment.
                Own up to the fact that you made a mistake: you didn't understand your business volume, you thought you could turn lead into gold with the machine, or you were suckered in by the pitch of a sales guy who doesn't understand what he's selling.
                • bobbykerr
                  • Sep 2012
                  • 52
                  #23
                  Ive got to say if you're running a copy shop with 20cpm b & w machine you're gonna need
                  to spend more time copying and less time continuing this ridiculous rant about what you were sold or you're gonna be spending most of the night finishing off your customers copying
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    #24
                    One piece of info that is conspicuously missing: Just what was the salesman told the need was?
                    Once a sales person sees that he will be getting a very minimal order, they don't normally put much effort into the deal. He has bigger fish to fry that actually help pay the bills.
                    Don't expect a sales consultant for the price of an order taker. It just doesn't work that way.
                    • Tonerbomb
                      • Feb 2005
                      • 2589
                      #25
                      and the memories continue...........................
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        #26
                        And his $400 "wonder box".
