automatic switch over tray - printing
  • Mark Bbb
    • Jun 2012
    • 1662
    Although auto tray switching is off, switching occurs when paper tray is empty.
    It only does this with printing, not copying.
    We have checked the settings via WIM, loged in, "configuration", "printer", "basic settings", "tray switching" is "off"!!!
    Anyone an idea?
    Thank you in advance.
    Greetings,
    Mark
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: automatic switch over tray - printing
    If you want a machine to completely ignore a tray unless specifically told to, uncheck Apply Auto Paper Select in the tray settings section of User Tools.
    Hit it.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Also, if you are using a universal type driver, the print jobs are sent individually. The machine interprets the resulting print calls as 'many auto tray selects', instead of 'just auto select the first tray available for everything'. (Kind of hard to explain)
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Not really hard to understand once you speak "Ricoh ese"
          • 37533
          If you only want to pull paper from a specific tray for a print job, you have to specify the tray in printer properties for the job.
          • Mark Bbb
            • Jun 2012
            • 1662
            Slimslob: that is correct, but it needs more time and manipulations to print. We have put the settings according to TonerMunckeh, and it works fine now! But thank you all anyway for the good info!
