Can you set print/copy quotas on Ricoh MFDs
  • scoobysteve
    • Jun 2008
    • 163
    Hi All,
    as the topic suggests, are you able to set quotas on the amount of prints/copies a user can do?
    Any help would be great.
    Regards,
    Steve
  • lvsb
    • Aug 2008
    • 70
    Steve,
    Ricoh machines can only track the number of copies and prints made, they cannot limit the number of prints
    • scoobysteve
      • Jun 2008
      • 163
      Hi,
      thanks for the confirmation.. you wouldnt know of any third party device or software than can do that function? One that is know to work with Ricohs?
        • 23010
        Scooby,
        I am assuming that you are talking about setting copy minimums when setting up service agreements. Maybe I'm crazy, but I like to see my service contracts at least break even.
        Segment 1 & 2 machines I never go below 1000 cpm. Even at 1000 copies there is the possibility of going unprofitable if your customer is high maintenance.
        Segment 6 machines I never go below 25K.
        If you have history with the customer, and you know that they won't call every time they get a paper jam you can let those numbers stay at the low end. I hope this helps. =^..^=
        • lvsb
          • Aug 2008
          • 70
          Equitrac or Hecon are two but I am sure there are others.
          • scoobysteve
            • Jun 2008
            • 163
            Hi,
            I've got a client who wants his staff to have a set amount of prints/copies and when they hit their quota, they will have to ask for more - just for management.
            I havent had to much to deal with equitrac but i think it might be too advanced/overkill for this client.
            thanks for the help guys. i really appreciate it.
            • Ricoh-ono
              • 340
              I have installed at least 10 Hecon counters on Ricoh machines. All were implemented without a problem. The customer can even order a handheld printer to print off counts from the Hecon device.
              Do what you can, with what you have, where you are. ~Theodore Roosevelt
              • Lagonda
                • Aug 2008
                • 1649
                Softlog is another supplier of external charge managment devices. Their based in Brisbane.
                • scoobysteve
                  • Jun 2008
                  • 163
                  Hi,
                  I didnt want to go down the path of softlog but ah well, looks like that is what it is going to look like.....
                  • SGT_Snacks-64
                    • Oct 2007
                    • 157
                    The best solution would be to leave it, set up user codes for Printing and copying, and ensure the management inform all the employees using the machine that they have x amount of copies/prints a month, if they go over it, they have to pay out of their pocket. Equitrac is certainly an overkill and needs to be rolled out as a big organisation "Like a council or a large Insurance business" and deals a lot with IT.
                    Hope that helps (?)
                    Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
                    Asus P5E-VM HDMI
                    4GB (2x 2GB) Corsair XMS Xpert II RAM
                    ATi Radeon 4870 512MB GFX Card
                    2x 74GB WD Raptor Sata HDD (RAID 0)
                    500GB Seagate Barracuda Sata II HDD
                    500GB Hitachi Sata II HDD
                    600W500att OCZ PSU
                    -TOTAL HDD SPACE 1148GB-
                    • cobiray
                      Passing Duplication Xpert
                      • Mar 2008
                      • 1199
                      Agreed, user codes are the way to go with out a 3rd party set up of some kind. Plus, it comes with the equipment so it costs nothing more than what the machine does.
                      • Kasseiken
                        Just put a card terminal next to the machine and set it up that your client has a card with for example 5000 credits (1 credit per copy)
                        After the limit is reached the copier awaits a new card with credits.
                        It's not the best solution but it might work.
                        • scoobysteve
                          • Jun 2008
                          • 163
                          Hi All,
                          thanks for all your input so far.. it has been helpful... i didnt want to tell the customer that you can't do it then find out that there is a simple way that you can..
                          the card terminal will be okay for the copying side of things but the printing will still need to be accounted for. I know the users can always print then release their jobs later using their code etc (this is how i did it at university) but then they still have to wait.. this will be a major problem if it is a lengthy print.
                          Once again, thanks guys.
                          • cobiray
                            • Mar 2008
                            • 1199
                            You do not have to use locked printing in order to track the printing with user codes. The code can be put in each time a job is printed (used in single pc - multi user) or can be input in the printing preferences (one pc per user).
                            • scoobysteve
                              • Jun 2008
                              • 163
                              Hi,
                              Entering the user code into the print driver isnt a issue but it doesnt offer a quota restriction which is what i need to have....The terminal will offer quota restriction on the copying side but not on printing.
