MP7000 Low density
  • rajmer
    • Dec 2008
    • 22
    MP7000 Low density
    Hi, I have problem on MP7000 with low density copy after 100K from developer replacing. I must forced toner supply a few times if I want that copier works normaly but this is not kind of solution. I know the problem with toner MP9002!
    Do you have any experience with this issue?
    thnx
    rajmer
  • logrady2331
    • Feb 2011
    • 301
    Re: MP7000 Low density
    Technical bulletin 018. Reissued 6-29-12. That bulletin covers this issue.
    • rajmer
      • Dec 2008
      • 22
      Thank you logrady2331,
      I don't have MyRicoh admittance if you be so kind and explain bulletin.
      thank you
      • Ottawatech
        • Feb 2015
        • 63
        TSB uploaded.
        Nothing works quite so well that I can't totally disable it by trying to make it a little better.
        • teebee1234
          • 1670
          you should also remove the doctor blade assy. and clean any buildup on the back side of the blade. The buildup reduces the height of the developer brush and contributes to light density.
            • 37072
            There is a doctor blade cleaning tools listed in the D059 service manual. A2949560 Paper Dust Cleaner - 5pcs/set. See 3.8.4 CLEANING THE DOCTOR BLADE in the manual for how to use. I have used them on the 60-90 page machines with no problem. Just clean before you dump the old developer so that all the crud get dumped.
            • Codex
              • May 2008
              • 694
              We had the same problem here in Italy... Tried everything possible, but there are only two solutions if the problem is the type 9002 toner...... Change developer every 50 or 100k copies.... Or use another toner. We have here again the type 9002, but this time something in the mixture changed.... The problem gradually disappeared.... I guess they changed some chemical component......we had a lot of angry customers and almost 200 machines from the d 1060 to Mp 8000 with exact the same problem. Use the new toner and your problem will disappear
              Memento Audere Semper
