ricoh 4500 replacing hard drive
  • dustzona
    • Mar 2015
    • 83
    i need to replace the hard drive on a mpc4500 . do i need to format the HD in FAT ? what is the procedure. thanks
  • rthonpm
    • Aug 2007
    • 2859
    Re: ricoh 4500 replacing hard drive
    Let the MFP format the drive. Ricoh uses a Unix format for hard drives so even if you format it, the device will just wipe it out in favour of its own file system.
    • mikadonovan
      • May 2008
      • 2931
      Just install the drive and execute sp 5832-1. Be sure and back up the address book if possible.
      NEVER ASSUME ANYTHING
      • dustzona
        • Mar 2015
        • 83
        how to backup address book ? do need a thumb drive? or is this a SP mode
        • ss12
          • Jul 2008
          • 289
          Easiest way is to backup via wim
          • PJF
            • Jul 2014
            • 32
            5846 51 I believe is the SP mode, back up to a SD card. then after the HDD change/format 5846 52 to restore the backup.
