ricoh mpc4501 i/h coil
  • johnny32
    • Oct 2007
    • 102
    Hi All
    Anyone know the part no for the thermal fuse within the i/h coil as i have a blown one. Cant find it in parts manual. If not available anyone know of a thermal fuse i can use instead rather than order the whole unit.
  • skynetto
    • Sep 2012
    • 257
    Re: ricoh mpc4501 i/h coil
    If its not fisically broken place some duct tape on top of it and the remove the tape as fast as you can. Hopefully the thermal fuse will pop back so you can save yourself from bying the whole ih
    • Ottawatech
      • Feb 2015
      • 63
      Yup, the tape method or giving it a quick rap on the backside to pop it back sometimes works.
      Is this the part you're looking for?
      Nothing works quite so well that I can't totally disable it by trying to make it a little better.
      • qbert69
        • Mar 2013
        • 1152
        Freeze Spray?!...or canned air turned upside down?!
        I believe the thermal "poppers" use a bi-metallic composition where if one of the metals gets hotter, it warps the bi-metal switch to break the circuit. You're just trying to reverse the process!
        Good Luck!
        PS--if you have one of the Katun/Snap-On ratcheting handle magnet screwdrivers, you can smack the thermal switch on the concave part of the handle to reset it!
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
        • sandmanmac
          • 3979
          Some interesting solutions here.
          I Had on just last week. Tossed it in the freezer for several hours, then gave it a good slam (face down) on a table, popped right back out.
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            If the coil's thermal fuse has blown, then the cooling fan is blocked or damaged, and may also need replacing.
            • Coptech
              worker drone
              • 460
              So far the only ones I have seen blown were from the crap design of the fuser being able to be removed and the customer thinks it is some sort of "pushbutton" that they try to reset when it jams. I have never seen one pop without help on these machines.
                • 37379
                Or some one decides that it looks dusty when they have it out and try to dust it off. Tech support told me that once.
