strange issue with ricoh mpc3003
  • en.
    • Jul 2014
    • 124
    hi all
    the device give error massage and touch screen not responding and i cant make any upadta firmware
    i repalce (hdd, touch panel , pcb control board ctL but problem is still now
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: strange issue with ricoh mpc3003
    Check the SC code history.
    Nobody is perfect..
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Turn off the auto restart function in service mode. Then the machine will just stop and display the error code. It's in the sp 5xxx's, don't remember right off the exact #....................
      Mystic Crystal Revelations
        • 37515
        SC Auto Reboot SP 5875-001.
        • en.
          • Jul 2014
          • 124
          sir
          touch panel not responding how i stop the sp (auto restart )
          • Mark Bbb
            • Jun 2012
            • 1662
            perhaps not so intelligent, but it might help: unplug machine from current, remove HDD connectors, put it back on...
              • 37515
              Originally posted by en.
              sir
              Perhaps the service code being generated is related to the touch panel. If that is the case and you have a machine with the SOP, the solution is to replace the touch panel.
                • 37515
                One more thing to try before replacing an SOP. Turn the power off then unplug from the wall and hold the power button until the power light flashes on then off. This will fully power off the machine and discharge the power supply. When the power is plugged back in the SOP will do a full reboot instead of a quick start.
                • morgansterne
                  • Oct 2007
                  • 83
                  greetings to Baghdad from the United States, hope you are well.
                  It's displaying sc870-01 in the bottom of the screen.
                  like the previous poster said, try booting it up with the Hard drive unplugged. If that gets rid of the error, the problem is your hard drive.
                  Try replacing the HDD. It doesn't have to be the exact ricoh part, just check which type of HDD it is and replace it with same size/same type HDD.
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Good job man...I,for one,totally missed that there was a code on the screen until you pointed it out...well spotted
                    • Gift
                      • Mar 2011
                      • 2459
                      Typical SC 89x software issue (not displayed but logged in SMC if you look) - usually not relly hardware related but triggered by faulty/corrupted print jobs. Try to keep FW and drivers up to date.
