Can you save a file scanned to doc server using WIM?
  • copyaction
    • Oct 2007
    • 985
    Setting up an mp2851 on iMac and as a workaround for scanning can you save a file stored on the doc server when viewing on WIM?
    we can print the file from there is there also an option to save?
  • zed255
    How'd ya manage that?
    • 1024
    Re: Can you save a file scanned to doc server using WIM?
    Only if the File Format Converter option is present.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      I don't think I've ever actually seen that option in the field.
      Too little known, I guess.
      Set up FTP on the iMac or send to email.
      • Iowatech
        Not a service manager
        • 3930
        I always wondered what that option was for. There was no call for it out here on the periphery, well, in this part of the periphery anyway, so I never knew until right now.
        Thanks!
        • bob marley
          • Jan 2012
          • 1339
          First time to know that. Thanks zed
          Live for yourself and you will live in vain. Live for others, and you will live again
            • 37345
            If you can print it, you can use a PDF rendering software such as Nitro PDF or Primo PDF as the printer and create a PDF file.
