Vaccuum
  • tufbnme
    • 493
    Vaccuum
    Don't use one very often but when the big spills occur it's a must. My old school 3M vac has finally given up and am looking for a replacement. I am wanting something MUCH quieter. Anyone have any suggestions?
  • allan
    RTFM!!
    • 5462
    Re: Vaccuum
    I have thought about using the filter inline with something else before.
    You can try a Convac. But they will overheat trip out and need to cool down from overuse.
    Its good for a copier not for a car.
    Whatever
    • omorales
      • Mar 2015
      • 86
      Re: Vaccuum
      karcher
      • tufbnme
        • 493
        Re: Vacuum
        Karcher seems kinda big to carry around.
        • allan
          RTFM!!
          • 5462
          Re: Vaccuum
          The dust/toner filter is the trick. If its not made for fine toner powder the toner melts into the bearings and seizes the motor up.
          Whatever
          • ZOOTECH
            Senior member of CRS
            • 3375
            Re: Vaccuum
            And, throws a fine toner dust throughout the area.
            • Polarbear
              • Feb 2012
              • 1070
              Re: Vaccuum
              3M is about the only manufacturer (i am aware of) that does toner vacuums.
              We recently had some repaired (we also use 3M) by a local company that does electrical motor rewinding and motor replacement.
              Press the GREEN button!!
              • Elmtech
                • Nov 2013
                • 155
                Re: Vaccuum
                Thats the vacuum i use. Easy to carry, has everything u need internally stored, the cartridges are easy to change and they come indifferent type filters for regular, hepa etc.
                • Elmtech
                  • Nov 2013
                  • 155
                  Re: Vaccuum
                  Linklink
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Re: Vaccuum
                    Bad Request
                    This is the one I have. God only knows why it's $466.
                    Hit it.
                    • allan
                      RTFM!!
                      • 5462
                      Re: Vaccuum
                      Convac also does a toner vac. Its not a noisy but i prefer the 3M with the TYPE 2 filter.
                      Whatever
                        • 37529
                        Re: Vaccuum
                        Try Atrix. Ebay has a number of them listed at prices starting from $85.00. Look very similar to the 3M. Atrix also makes filter that fit the 3M copyvac.
                        • bryand
                          • Jul 2008
                          • 92
                          Re: Vaccuum
                          We use 3M vacuums, they are a bit noisy. Only use it on Ricoh calls, worst toner dumping machines ever made.
                          • allan
                            RTFM!!
                            • 5462
                            Re: Vaccuum
                            That is a lot less expensive!!
                            Whatever
                            • Leebs14
                              • Feb 2014
                              • 457
