ricoh mpc 2051
  • kopirmaster
    • Apr 2011
    • 70
    ricoh mpc 2051
    call paper misfred ,dont reset and there no marks where is paper misfried
    picture in atachment 0b95050d920b7b5878b6a13c9baaa0b0b9bfb934b91c39440850fd421b074dbd.jpg
  • Zeldaman
    • Mar 2011
    • 946
    Re: ricoh mpc 2051
    Hi there!
    This model of the "Diana"-series has the modified clutches, so you have to clean the feedrollers and CHANGE the pads. Also look if the paperend-sensor is in its correct mounting-position.
    Greetings...
    • kopirmaster
      • Apr 2011
      • 70
      Re: ricoh mpc 2051
      Originally posted by Zeldaman
      Hi there!
      Greetings...
      I know that ,problem its that the machine wont reset paper jam ,and dont show whare is 'paper jam'
        • 37508
        Re: ricoh mpc 2051
        The picture you provided shows a J001. J001 is a jam found at power on or door closure. You need to check the jam history is System SP to see where the last actual jam occurred. Then check to see if there is a scrap of paper setting on the sensor.
        • kopirmaster
          • Apr 2011
          • 70
          Re: ricoh mpc 2051
          the problem was sensor actuator stock ,sensor that is for paper tray 3 .machine only have cabinet
          thanks for replay
            • 37508
            Re: ricoh mpc 2051
            Sometimes a power surge or stormy weather can cause a memory corruption. I hope that you have the birth certificate or a recent non-default print out as the only correction is do an engine memory clear SP 5801-002 and you will need to reload the non-defaults.
