ricoh 2018d, problem jamming
  • tullio
    • Feb 2012
    • 268
    [Jamming] ricoh 2018d, problem jamming
    the jam card , exit the oven.urgent.
    thank you
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: ricoh 2018d, problem jamming
    1. Check stripper fingers in the fuser unit(oven)are all ok.
    2. Check the press roller in the fuser has not jumped out of its home position.
    3. Check the main drive gear rotating the fuser unit is not cracked or spinning freely without driving.
    4. Check the side door paper guide into the fuser unit is not cracked or broken. The paper guide must line up with the fuser unit when the side door is closed. If any of the guides are broken replace the whole guide assy.
    5. I believe there was a lower fuser case modification to fix associate problems with the hot roller moving out of its home position.
    HTH
    • tullio
      • Feb 2012
      • 268
      ok . but the same problem .
        • 37511
        Check that the rollers in the paper exit are turning and that the flag for the exit sensor is not stuck and blocking the paper path.
        • Polarbear
          • Feb 2012
          • 1070
          +1
          Looks like the paper is forced out of the fuser, but not being fed further on, therefore the wrinkles.
          Press the GREEN button!!
          • Elmo
            • Feb 2010
            • 541
            Originally posted by tullio
            [ATTACH=CONFIG]31723[/ATTACH][ATTACH=CONFIG]31724[/ATTACH]
            thank you
            what weight of card are you using
            as previous posters have stated it looks like it is exiting the fuser unit then getting stuck at the exit rollers
            is it ok with paper
            I Used To Live To Fix Things Now i Fix Things To Live
