MPC 3500 light copies/prints
  • Chrief
    • Oct 2014
    • 30
    I cleaned/checked pump all ok,( also swapped with a working one) vacuumed tube, tested toner supp motor (output test ok)
    Performed force toner supply/dev initialization. added toner manually into unit and initialized TD, worked fine for a month, now same problem. Any advice should help.
  • logrady2331
    • Feb 2011
    • 301
    Re: MPC 3500 light copies/prints
    Not sure what you mean by "tested toner motor" as there isn't one in this machine. It uses a pump which is driven by the drum drive motor assembly. If the drum is turning then the pump should be turning. Of course the pump has to be coming on when the IO board tells it to. How old is developer? How old id the developer unit?
    • logrady2331
      • Feb 2011
      • 301
      Sorry, I think you meant the toner bottle motor? A lot of things can cause this issue. Are you getting an add toner message or are the copies/prints just light? You have cleaned the LSU slit glass right?
      • Chrief
        • Oct 2014
        • 30
        add toner mssg not flashing, cleaned laser optics as well.. I mean if its the
        laser optics, than when i add toner manually, it should be the same (light copies).
        • NeoMatrix
          Senior Tech.
          • 3513
          Don't try to clean or refurbish the toner pump, just replace the toner pump with a new one.
          HTH
          • prado
            • Aug 2013
            • 7
            Try swapping the IO board sounds like the toner pump is working if you can manually tone up
            • copier tech
              • 8195
              If doing a forced toner supply the quality returns to normal then you can rule out the toner pump.
              Is this happening on black only? if so what is the K dev & pcu life?
              light or faint copies & prints is a classic worn developer symptom
                • 37562
                Try running Auto Color Calibration in the Maintenance portion of User Tools. All mirrors in the optics should be cleaned first.
                • Chrief
                  • Oct 2014
                  • 30
                  I visibly checked the Dev unit and it seems there is no toner pumped into the unit, after i manually poured toner into unit,
                  it came out OK, the clutch on the pump unit comes on during output test. I also changed complete pump unit with a new one.
                  * Can i be able to tell if there is suction by blocking the tube nozzle?,..
                    • 37562
                    Did you replace with a new part number for toner pump assembly (which the transport tube) or did you just replace the pump only, possibly from another machine? The tube will clog and take the pump out. A clogged tube can also cause a clog at the toner valve at the back where the toner bottle feed into.
                    • hossam
                      • Aug 2010
                      • 70
                      Have you tried to clear the memory?
                      Make sure to print out non default programs before memory clear
                      Sent from my GT-I9300 using Tapatalk
                      • davel
                        • Oct 2011
                        • 1108
                        Agree with this and check that toner end detection is not turned off.
                        • mrwho
                          Major Asshole!
                          • 4299
                          I usually, for troubleshooting, clean out and swap the pumps between colors.
                          Mascan42
                          Ibid
                          • skynetto
                            • Sep 2012
                            • 257
                            There are some things to do here. Make sure devs are not worn out.
                            First check with SP3045 if toner end detection is off.
                            Have a full clean of the ID Sensor (the PCB above the ITB).
                            Check if the Process Control is set correctly to their default values, following this:
                            SP3041-001 = 1
                            SP3041-002 = 1
                            SP3051-004 = 2
                            • Zaxxon
                              • 608
                              Memory clear doesn't give you anything but more trouble, don't!!!
                              Please start you post with brand, model, problem.
