Firmware Update Via USB?
  • Timmytronic
    • Oct 2010
    • 249
    Hi, I keep on losing or mislaying my SD cards, I just wanted to know if I have the Firmware on a USB stick can I just Login to the copier via the web server way, and go to Firmware and choose the Firmware on the USB stick in the computer I am using to login into the Copier system?
    Do I need to have anything special on the USB stick like them in a Romdata folder or as a Package.? I was going to do this onto a MP c5502 and Mp c8002
    Thanks for any advice.
    Tim
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: Firmware Update Via USB?
    Yes you can push frimware via the web interface. You have to use the remote frimware version, that's the rfu file type.
    Mystic Crystal Revelations
      • 37484
      I always keep an SD card in the SD slot on my laptop. That way I always know where it is. If it is not there, it is in the last machine I updated firmware on.
      • Timmytronic
        • Oct 2010
        • 249
        That made me laugh a lot! Thanks Slim.
        • Superbug
          Hi, where can I find the firmware .RFU ? in Italy seem to be available
          • copier tech
            • 8144
            I usually remove java cards from any machine that's not using it & use them for firmware, I label each card with a machine model number & keep the firmware on each up to date saves a lot of time downloading over & over again!
