MP161 , MP171, MP201 Side Door?
  • JonManchester
    Technician / Shop Manager
    • Aug 2013
    • 103
    I have been seeing a lot of side doors by the latch handle break and have to replace the whole door. Is there a mod that someone has come up with to make that half moon piece of plastic more rigid. If so id like to mod these doors so i don't have to replace so many of them in the future. Also they aren't cheap, i think they are just under $100.
    Live for something or die for nothing.
  • Iowatech
    Not a service manager
    • 3930
    Re: MP161 , MP171, MP201 Side Door?
    Those are pretty old machines. It sounds like either those pieces got brittle thanks to heat from the fuser or the users aren't being patient enough when opening and closing that door. (Heh, I still carry the fuser duplex guide as car stock because of that.)
    If you ever take any of those back on a trade in, it's actually pretty productive to harvest that door off those machines. And easy too.
    • Polarbear
      • Feb 2012
      • 1070
      Hi
      One of our techs has come up with an emergency fix by drilling 2 small holes in the door and threading a white cable tie strap through the holes and around the shaft of the door release (keeping the catch part inside the door so that only a little bit of the cable tie is visible outside). This seems to hold up so far.
      Press the GREEN button!!
      • StephenB
        • Aug 2015
        • 239
        Originally posted by Polarbear
        Hi
        Been doing that repair with a white cable tie for years, never failed
        • NeoMatrix
          Senior Tech.
          • 3513
          Whenever you get time ,post a photo of the repair job to CTN, I'm interested in any fix-in-the-field repair jobs.
          • JonManchester
            • Aug 2013
            • 103
            I have just modified a couple of doors and just want to says thanks to all that posted on this thread.
            • JonManchester
              • Aug 2013
              • 103
              Here are a couple of images from the mod I did yesterday.
              • copyaction
                • Oct 2007
                • 985
                nice, thanks for the pics.
                • NeoMatrix
                  Senior Tech.
                  • 3513
                  Originally posted by JonManchester
                  [ATTACH=CONFIG]31915[/ATTACH][ATTACH=CONFIG]31916[/ATTACH]
                  Thanks...
                  I've virtually done the same type of fix ...
