Ricoh SP 8300 PCU compatible with MP 4002/5002 machine?
  • mrizer
    • Mar 2009
    • 70
    [Misc] Ricoh SP 8300 PCU compatible with MP 4002/5002 machine?
    Does anyone know if the 407057 will work with out a mod in the MP 4002 and 5002, which uses pn D1292110? I know the same is true for the SP 8200 and the MP 4000 series.
    Michael Rizer
    Free Technical Support
    Item Inc. 800-367-4836
    mrizer@iteminc.com
  • copier tech
    • 8235
    Re: Ricoh SP 8300 PCU compatible with MP 4002/5002 machine?
    Yes you can use that, we order the SP unit as it's a lot cheaper!
    You just need to swap a wire over, just compare the old unit with the new
    • mrizer
      • Mar 2009
      • 70
      Awesome...I will order one up and give it a try.
      Thanks for your help.
      Michael Rizer
      mrizer@iteminc.com
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        WE still use the sp8200dn unit for the 4002/5002 and haven't struck a problem.
        • mrizer
          • Mar 2009
          • 70
          Do you have to move a wire over on the SP 8200 to make it work?
          Michael Rizer
          mrizer@iteminc.com
