Faxing Ricoh/Lanier
  • mikedci
    • Jul 2010
    • 227
    Faxing Ricoh/Lanier
    Has anyone used a device like this? Looking at it for an LD630c.
    Good, Bad, meh?
  • copier tech
    • 8131
    Re: Faxing Ricoh/Lanier
    I used to see something simalar all the time, it was called a fax switch, great if the customer only has one phone line but whats to receive faxes while they're out of the office etc.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Save yourself a TON of grief and insist that the customer get a DEDICATED line for faxing.
      You obviously can't force them to, but make sure they understand (ideally in writing) that you can't support it if they go the cheap route.
      I'm sure that some of these switches work better than others, but there is never any guarantee they will work reliably.
      It's been years, but I never had a good experience with these things.
      It doesn't matter at all what your fax device is, the premise is the same. Iffy, at best.
      • Iowatech
        Not a service manager
        • 3930
        If this is like "The Stick" I've seen a couple of times, if the customer takes full responsibility for the thing, go for it. While historically speaking fax switches have been somewhat dubious, the people using "The Stick" didn't complain to me about fax problems the two times I've seen it.
        (Having only two examples makes this specific reply a statistically insignificant study. So take it for what it is worth.)
          • 37382
          These have been around for years. They work great when they work.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Anything that delays the answering device from picking up and sending fax "tones" increases the possibility of a timeout on the sending end, creating an error.
            If there is time to spare, great. If not, well, not so great.
              • 37382
              If the stick is the same as ones I have used in the past, it uses the "CNG" tone to detect an incoming fax. Back then, the CNG tones was only sent when you used an address book entry to dial. If you manually dialed the number, it would not work.
              • mikedci
                • Jul 2010
                • 227
                Thx for the replies. Phone company wants to charge them $30/month for an extra line and they're looking for alternatives...
                  • 37382
                  There is always the online options.
                  eFax -
                  Vonage - VoIP Fax Line - Add a Dedicated Fax Line - Vonage
                  I used eFax in 2005 when I was deployed to Iraq. Two other seniors NCOs and I had accounts. If anyone in our company needed information from their home units to put in a promotion packet, all they had to do was email their unit and have the information faxed to one of our eFax numbers. We usually had it within 24 hrs. To have it mailed to 10 days or longer.
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    Their business isn't worth a measly $30 a month to them for the reliability that the additional line would offer?
                    Sheesh.
                    • mikedci
                      • Jul 2010
                      • 227
                      Sheesh.
                      It's a small church so they dont do a ton of faxing and I guess money is tight.
                      • Tonerbomb
                        AutoMajical Resolutionist
                        • Feb 2005
                        • 2589
                        command communications com switch 7500 or 5500 is a much better device, and more reliable.....
                        Mystic Crystal Revelations
