Ricoh MPC 5000
  • bomberi
    • 107
    Ricoh MPC 5000
    Hello, Can some one tell me how to reset SC863 code on MPC 5000 or send me the docs tech for this model.
    THANKS.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MPC 5000
    Remove the HDD and format it with a USB caddy.
    Hit it.
    • bomberi
      • 107
      Re: Ricoh MPC 5000
      No any way to reset the machine? I'am canon Technician not ricoh but I want to solve this problem. Thanks
      • bomberi
        • 107
        Re: Ricoh MPC 5000
        Please Can you send me the way to enter in sp 5-832-001. Thanks.
        • TonerMunkeh
          Professional Moron
          • 3865
          Re: Ricoh MPC 5000
          Tap the yellow key, 107 then press and hold the red stop key. Press system SP. Type in the SP number and press #. Then press execute. If it fails you will need the service manual for instructions on how to pull the drive and as mentioned format it with a USB SATA caddy.
          Hit it.
          • bomberi
            • 107
            Re: Ricoh MPC 5000
            I try this and the copier is ok thank you for help.
            • TonerMunkeh
              Professional Moron
              • 3865
              Re: Ricoh MPC 5000
              It may throw the code again. Machine formats with SC86x codes rarely fix the drive properly.
              Hit it.
                • 37533
                Re: Ricoh MPC 5000
                SP 5832-001 does not actually format the disk. It merely erases the directory tables and recreates them.
