MPC3500 vertical white line
  • vga_man
    • 78
    [Misc] MPC3500 vertical white line
    Hello everybody!
    I've Ricoh mpc3500.
    Three days ago seen vertical white line specially with cyan.
    Cleaned charge roller,drum and laser but the line still appears1456047073727788689159.jpg1456047073727788689159.jpg
  • skynetto
    • Sep 2012
    • 257
    Re: MPC3500 vertical white line
    Clean doctor blade in the cyan developer group
    Inviato dal mio GT-I9505 utilizzando Tapatalk
    • copier tech
      • 8144
      If you're sure the last glass is clean, I agree looks like its a deletion in the cyan dev unit. Spilt the drum & dev units, rotate the dev roller & look closely, you should be able to see the deletion, line it up with the copy for confirmation.
      To get rid of the line run a sheet of paper under the blade & swipe it to the side, repeat as necessary, its caused by a lump of developer or build up of paper dust etc.
      • vga_man
        • 78
        Thanks alot !
        It is Working...
