Firmware update using WIM or remote
  • Hadster
    • Aug 2011
    • 264
    [Misc] Firmware update using WIM or remote
    Can you update firmware using the web image monitor or a remote? I'm not a dealer, so I use FMAudit to retrieve my meters for example. I've only done it with a SD card but I have several customers that are 3 and 4 hours away. It would definitely save a lot of time and money if I were able to do so! Thanks for any help!
  • sharpmind
    • Sep 2009
    • 478
    Re: Firmware update using WIM or remote
    Yes, you can. Download remote firmware update file (.rfu). But I prefer manual firmware (using SD card) update because it is safe.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      It may be safer (OK, it IS safer), but being on site is not always practical, especially when great distances are concerned.
        • 37513
        When you are doing remote firmware updates, you do one module at a time. Also, they do not have package firmware for remote update. Personally I do not like to push that much data over an internet connection. If it is at all possible, have a machine at the customer's location that you can remote into and do the updates through that. You can also look at meters using WIM or Smart Device Manager NX. SDMNX allows you to search an entire IP range for machines and create a CSV file. Both WIM and SDMNX break color down into separate full color, 1 color and 2 color totals for each function, print copy, fax.
        • sharpmind
          • Sep 2009
          • 478
          I'm sure it is paid job so I don't see any problem traveling long distance.
          • Hadster
            • Aug 2011
            • 264
            95% of my customers are under service contracts including said customer so yes this would be of great benefit to me!
            • tufbnme
              • 493
              Very risky, if you do, make sure that no one touches the machine while updating. Have the customer unplug the fax line if it has one. It can take a while updating each file, plus the machine will restart after update is done. Be sure the customer knows this and as I said before make sure no one touches it while updating.
                • 37513
                Depending on the model of the machine, it might restart after each module.
                • pppp
                  Technical specialist
                  • Sep 2010
                  • 43
                  1. At the moment Ricoh does not publish files for remote update (.rfu) in Europe at all - happily.
                  2. You have 100% of machine failure after remote update when even unimportant alert (paper end, toner end etc.) is visible on machine display
                  3. Remote update is extremelly time wasting work. You have to update every firmware one by one and reboot machine every time.
                  So, do not do remote updates because this is piece of sh.t.
                  Microsh.t is finished and Linux Rulez
