MP2851 not recognizing fax unit
  • copyaction
    • Oct 2007
    • 991
    have an mp2851 just installed fax module it sent 1 fax and now the receive file light is lit and it doesn't see the fax anymore
    Going Back for another fax board just wondering if there's anything, common the causes this
  • mikadonovan
    • May 2008
    • 2931
    Re: MP2851 not recognizing fax unit
    Since the machine recognized it before, clear the fax application and reseat the fax boards.
    NEVER ASSUME ANYTHING
    • copyaction
      • Oct 2007
      • 991
      Yes I tried that while I was there and reseated the small board with the battery on it on the fax unit
      • copyaction
        • Oct 2007
        • 991
        Is the fax unit for the mp2550b the same?
          • 37491
          NO, the FCU board might be the same but the MCU board where the firmware resides is different. Check the parts catalogs.
