Aficio 450 drive motor change the rotation speed
  • aleiglesias
    • Aug 2025
  • FRIDGEMAGNET
    • Aug 2007
    • 377
    Dip switch 101 on the IO board.
    Make sure switch 1 is off.
    These set the speed of the machine.
    • aleiglesias
      • chris
        • Jul 2008
        • 10
        I don't really understand what you are saying in changing motor speed but most times jamming out of the tray on these machines is a bad paper feed clutch.
        • aleiglesias
          I'm sayin that the motor rotates down the standard rpm (the sound of the motor change); this only occurs when using trays 1 or 2 in single or series copies. I tested with another motor and it works ok. The question is why this trouble doesn't ocurr using trays 3 and 4
          • iMind
            Vacuum Cleaning Expert
            • Mar 2008
            • 1116
            Originally posted by aleiglesias
            If anyone knows the solution please answer me. Best regards
            • jctech
              • Oct 2008
              • 13
              The bushing of the 1st and 2nd tray are certainly in need of some lubrification i had this on my machine after long printing jobs, you should put some oil on it and then spread it over by activating the main motor and the respective tray clutch. this should do the trick for you.
              Information is meant to shared not sold!!!!
              • aleiglesias
                o brigado
                • jctech
                  • Oct 2008
                  • 13
                  did you solve the problem?
                  • aleiglesias
                    Yes I did thank you very much
