Mp 2852 upper fuser roller
  • COPIERMAN
    • Jun 2009
    • 559
    Does anyone know if the Mp 2851 upper fuser roller is same for the MP 2852 the parts book shows a different Part # but fuser assy looks the same to me. They are using same lower pressure roller
  • sandmanmac
    • 3983
    Re: Mp 2852 upper fuser roller
    I asked the exact same question a couple of months ago, and was told that it was.
    http://www.copytechnet.com/forums/ri...ht=#post499984
    • apump
      • Mar 2009
      • 160
      yes there different. 2852 is ae011128. the 2851 fuser roller will fit in there and work sort of. eventually you will start getting jamming and folding corners. I believe its the diameter.
      • sharpmind
        • Sep 2009
        • 478
        If I were you, I would try to do the testing and see the results whether it works or not.
