Richo mp c4500 Color
  • thew175
    • Jun 2025
    when I print to my c4500 the colors are all off. Like it is shadowed, not lining up to all print in the exact same area.
    This is how it prints. Any help would be greatly appreciated.
  • ccchuah
    • Mar 2009
    • 153
    Re: Richo mp c4500 Color
    SP mode set 2111-3 and 2111-1 will correct the image.
      • 37375
      Before you do that, clean the ID sensor assembly with clean cotton cloth dampened with water only. Do not attempt to dry it off ass this can generate static. Sometimes just cleaning the ID sensor assembly will allow the machine to adjust itself.
      • bob marley
        • Jan 2012
        • 1339
        don't forget Sp 2111-2 (Mode b )
        Live for yourself and you will live in vain. Live for others, and you will live again
        • Polarbear
          • Feb 2012
          • 1070
          +1
          A clean machine just runs better! Especially a colour one!
          Press the GREEN button!!
          • Elmo
            • Feb 2010
            • 541
            as slimslob said clean the id sensor 1st
            then in user tools select maitenance then run color registration
            if this does not align colors then go into service -- drum and run forced line position adjustment
            excecute adjustment c,b,a in that order
            I Used To Live To Fix Things Now i Fix Things To Live
            • andy227
              • Jan 2013
              • 219
              I always thought it was c and b, OR, c and a, but not all three together (and according to the manual).
              • Counsel
                • Aug 2011
                • 530
                Its actually run C first then A, the manual does not say to run B at all. Sometimes you may need to repeat the process if it isnt quite lined up, if you do this you really shouldn't have to do the one in user tools. If this does not correct it check your PM counts, a dragging drum or problem with the ITB itself can cause registration problems as well.
                Also if the line pos adjustment corrects it, I would power down and reboot and recheck, I had the NVRAM go out once and registration would be fine until someone powered off the machine and back on.
                  • 37375
                  Running a is the same as running b twice.
                  • Counsel
                    • Aug 2011
                    • 530
                    Is that what it does. Always wondered why it was there in the first place if the manual only wants c and a run. lol. thanks
