Ricoh MPC3003 4503 5503 white lines all colours
  • Lagonda
    • Aug 2008
    • 1649
    #16
    Re: Ricoh MPC3003 4503 5503 white lines all colours
    We're using;
    D186 3052 Cyan
    D186 3072 Magenta
    D186 3082 Yellow
    K is D186 3052 but being a 600k unit that costs twice as much, we're getting them for around $150.
    And remember that we are a major dealer so we get a good discount, you may not be able to get the same pricing from RA.
    • mynameis
      • Jun 2015
      • 78
      #17
      I'll second that. On the high volume Toshibas it's common to get "foreign matter" under the doctor blade. A quick swipe with my mylar cleaner tool, while rolling the mag roller forward pulls out the objects, without even removing the developing unit.
      I've tried the sifting with a Kyocera developing unit that had collected toner rocks in the developer overflow. The sifting itself was successful, but the developing unit died. These units were never intended to be disassembled, and the delicate little snaps are just dying to break when you look at them wrong. I did not discover that the drive gear had spun, until the developing unit was nearly re-filled of developer. It was educational ... and a complete waste of time. =^..^=
      Dear blackcat,
      could you drop a link to where to get such a tool?
      Thanks!
        • 23009
        #18
        Originally posted by mynameis
        Dear blackcat,
        Thanks!
        A Christmas ornament came in a clear mylar box, which I have been cutting up for the last decade or so. The result looks like this:
        • Counsel
          • Aug 2011
          • 529
          #19
          I don't if the dev unit costs more or less then just a bag of developer but I have only replaced a handful of developer units on the 03's and 02's models largly because the mag roller stopped holding developer and was pretty much cause half the page to be white.
          if its just small white lines I usually try to clear it with a piece of paper and turning the mag roller, if that does not clear it i just dump the developer and vacuum out the unit and clean it really well and refill it with new developer thats pretty much always solved the issue for me.
          • Lagonda
            • Aug 2008
            • 1649
            #20
            The only problem there is you can't get OEM developer.
            • Counsel
              • Aug 2011
              • 529
              #21
              [QUOTE=Lagonda;508824]The only problem there is you can't get OEM developer.[/QUOTE
              your right i guess i have really only needed to replace developer on the 02's which is fairly cheap for a bag. Most of the 03's we have out there haven't had many issues in general.
              • Gift
                • Mar 2011
                • 2459
                #22
                Originally posted by Lagonda
                Sorry guys, but don't agree with you. A new dev unit with dev is around $70 so its false economy to try to fix a faulty one. Just clean the doctor blade and you'll be back again when the lump resurfaces, open the dev unit and you risk damaging the seals and upsetting the TD sensor if you chuck away some dev to get rid of the lumps.
                And if anyone can explain how Ricoh can sell you a dev unit for $70 but want over $1300 for a PCDU and a $1000 for a PCU? The only explanation we can come up with is sheer greed.
                We've just sourced a non-OEM PCU rebuild kit, will get back to you with results after we've given it a test run.
                In the mean time I'll get back to putting in warranty claims for dev units that have failed within 3 months, there's 3 of them beside my desk at the moment.
                Hey there - any news about you "drum unit rebuild" experience? Usually I'm not a fan of this but due to the high price of the PCUs I'm pretty tempted
                • jeff33
                  • Aug 2009
                  • 61
                  #23
                  I have replaced so many dev units its not funny, I don't even try to clean them anymore I just replace them.
                  • bob marley
                    • Jan 2012
                    • 1339
                    #24
                    sometimes cleaning dev. unit can solve the problem and many techs used to do that
                    Live for yourself and you will live in vain. Live for others, and you will live again
