SMB scanning Windows 2012R2 Server
    • 30306
    have a C5502 and a C5502a
    that get fail to scan to folder.
    I can manually browse to folder and enter login and connect test shows good but it still fails.
    attach are the firmware Levels for both machine or is it something I missing?
  • sandmanmac
    • 3981
    Re: SMB scanning Windows 2012R2 Server
    Win 8/10, Server 2012, require Network Firmware version 11.96 or newer.
    There are dozens of threads discussing firmware requirements for windows 8/10.
    Rule of thumb: Every (Ricoh) machine that was built prior to the introduction of Win 8 will require an update to scan to it.
      • 37533
      What you attached it the printer configuration page and does not show firmware. Firmware printout is System SP 5990-005.
      • sandmanmac
        • 3981
        It does show the 5 main firmware versions at the top. That's how I knew he only has NIB version 11.93.3
          • 30306
          Thanks for the information. What is the current Level for the NIB?
          • anothertech
            • 1771
            Looks like 11.103
            • pppp
              Technical specialist
              • Sep 2010
              • 43
              Microshit has made some update for 2012 server failing SMB service.
              So, they released rollup update repairing they excellent work
              Microsh.t is finished and Linux Rulez
