Ricoh MPC2550 Keep Offline after 2 days
  • darknet93
    • Nov 2015
    • 89
    Hi, i have MPC2550 that always showing offline on my PC. it will goes offline after 2 days.
    sometime after i restart the PC the printer will be OK and after 2 days it happen again
    sometime if i restart my network like router and modem it will be okay. then after 2 days it will show offline again
    sometime i do both but still offline what should i do?
    i have update the firmware
    if i reset the nvram can setel the problem?
  • Ahmed Bushara
    • Mar 2015
    • 26
    Re: Ricoh MPC2550 Keep Offline after 2 days
    change the driver that you use.
    Thanks and best regards
    Ahmed Bushara
    Electronic Engineering technician
    Mobile: +249-999198804 /+249-123198804
    • darknet93
      • Nov 2015
      • 89
      Okay Will Try it later. if still happening what else can i do?
      • lukeh
        • Jun 2012
        • 43
        check driver and also try print to the IP under ports in the driver not host name
          • 37405
          Check the driver settings. Port tab, Configure Port, SNMP Status Enable check box. If checked, uncheck it.
          • qbert69
            • Mar 2013
            • 1152
            Like Previous posts said, make sure you have the correct print driver!
            Also, sometimes SNMP causes "offline" problems!...just go to your print driver settings and under the port configuration, turn off the SNMP function!
            See Post Here!:
            CHEERS!
            REACH FOR THE STARS!!!
            Konica Minolta Planetariums!
            • StephenB
              • Aug 2015
              • 239
              May also be an IP conflict.( another device or computer has "grabbed" the same IP as the Ricoh ) Unplug the Ricoh cat 5 connection and ping the IP address. If you get a response, there is a conflict.
              If so, change the Ricoh IP ( suggest doing a ping test to confirm the new IP is open)
                • 37405
                I had a similar situation at a county water agency. They had a new IT company. When we delivered new MFP, the IT people assigned an IP address for us to use. Occasionally printing would stop and they could not scan. Then it would start again. Usually by the time I got there it was working. Contacted IT and they said to use the next IP address in sequence and he would change the server. Worked for about 15 minutes. What we found was that there was a VPN connection setup on the router that the new IT people did not know about. The IP addresses that the new IT thought were good were actually part of the 5 address pool used by the VPN. Anytime someone from county data processing logged in to get information or update servers, they had a 1 in 5 chance of landing on the address the MFP was using.
                • SargeNZ
                  • May 2012
                  • 263
                  I'm going to remember this story next time I am on the phone with IT and they tell me there is 'no possible way' there could be an IP address conflict. Last time they told me that, someone was walking to the building with a cellphone that for some reason was set to a static IP the same as the copier. Whenever I got there, the person had left already.
                  • Counsel
                    • Aug 2011
                    • 529
                    Besides the driver I would have also guessed the IP being taken by another device. Usually we set the machine to static and use a high up IP like .175 or somewhere between 150-200 which lowers the chance of anything taking the ip since DHCP usually starts with the lowest range.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      It's always best to use a static IP address on the copier.
                      If it's set for DHCP, and gets rebooted, it may or may not get the same address next time, especially if the DHCP lease time is short.
                      Not likely, but something else to consider.
                        • 37405
                        One of the IP schemes that I use when setting up a network customer is as follows:
                        1. 001-019 for servers, routers and gateways.
                        2. 020-049 for high priority users who need to continue to have access to servers and printers when DHCP is down.
                        3. 050-099 for printers.
                        4. DHCP allocation starting at 100.
                        • qbert69
                          • Mar 2013
                          • 1152
                          Yeah....It's ALWAYS nice when IP addresses stomp all over each other!!!...If I am doing static, I like to make it high....usually 100+ so it doesn't interfere with the DHCP in the lower range!
                          *Usually* keeps everyone happy!
                          PS--my home router is a Netgear and it starts assigning DHCP in the lower ranges...I haven't experienced any problems *YET*!.....and if I do, it's usually Comcast!...LOL!
                            • 37405
                            I have seen some routers that start at 101.
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              My old Linksys home wireless router (about 6 years old, and recently croaked) started assigning addresses at .101.
                              The Netgear I replaced it with a few months ago starts with .1.
