Aficio 1515
  • Gab
    • Aug 2015
    • 668
    Aficio 1515
    Can i transfer controller from an Af 1515 mf o an af 1515PS? And if i can what's the difference ?
    • 37362
    Re: Aficio 1515
    First off service documentation does not show a Ricoh model Aficio 1515SP. The is a Lanier LD015SPF which is the same machine as the Aficio 1515MF.
    • allan
      RTFM!!
      • 5462
      Re: Aficio 1515
      There was 3 types the 1515f, 1515mf, and 1515ps.
      Fax, Multi function and Print Scan.
      I think if you add the f to the ps you get a mf.
      So you could loose the f.
      Whatever
      • allan
        RTFM!!
        • 5462
        Re: Aficio 1515
        Oops 4 types the 1515 copier.
        Whatever
          • 37362
          Re: Aficio 1515
          Product Support Guide shows only a 1515 , 1515MF and 1515f. The 1515 is a basic model, copy only.
          . The 1515f has copy and fax only and cannot add print/scan. The basic model doesn't have a controller box.
          • sandmanmac
            • 3979
            Re: Aficio 1515
            While the factory 'option" to add Print/ scan is not available. All that is required is to swap over the circuitry, and the extra components of the operation panel from a used machine to make a basic model into an MF. I did it myself several years ago.
            ...Also did the same thing on an MP161
              • 37362
              Re: Aficio 1515
              But the basic model can be updated. It is the fax model that can not.
              • Counsel
                • Aug 2011
                • 530
                Re: Aficio 1515
                Sounds like its time to upgrade.
