MP C6501 (aka duster producer)
  • skynetto
    • Sep 2012
    • 257
    Downloaded today from Ricoh Portal a new Engine firmware [Version] 1.11:06 with these modifications:
    [Modifications made:]
    Symptom corrected:
    - Toner scattering from the development unit.
    - Image density is low.
    NOTE: SP setting is required for this firmware to take effect.
    See RTB RD081049f for detail.
    Does anybody have the RTB they are talking about?
    Thanks in advance.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: MP C6501 (aka duster producer)
    Thanks in advance.
    TSRC here in the states has the same readme for that version frimwar. I couldn't find that rtb by that RD081049f number on TSRC or esource either.........
    Mystic Crystal Revelations
    • Lagonda
      • Aug 2008
      • 1649
      Here you go........and we've only got one of these toner spewing abominations left!!
        • 37458
        I haven't seen that bulletin before, but the adjustments look similar to those I have been making for years.
        Service Program (SP) Settings.pdf
        • skynetto
          • Sep 2012
          • 257
          Thanks a lot. I have only two left.
          @SlimSlob: I'm using your settings also with good results. Let's see if this frimware update makes things better.
            • 37458
            One other thing that I have found is that when then drum lube bars get warn down too far, waste toner will start to stack up between the cleaning blade and spreader blade causing color streaks and background. Cleaning will giver you about a week to get new lube bars, apply brush, and blades.
            • Lagonda
              • Aug 2008
              • 1649
              it didn't.
              The last one left belongs to a political party, they deserve it.
