MPC305SPF
  • chalky
    • Jul 2015
    • 8
    MPC305SPF
    Good Day
    Have a MPC305SPF the black toner light does not go out, toner is going into the toner hopper and into developer unit but light does not go out
    Any suggestions.
    Dave
  • Zeldaman
    • Mar 2011
    • 946
    • TonerMunkeh
      Professional Moron
      • 3865
      Re: MPC305SPF
      Pump might also have failed.
      Hit it.
      • Counsel
        • Aug 2011
        • 529
        Re: MPC305SPF
        I think there is a TSB on these as they are default set to say out of toner on bottle rotation instead of TD sensor, and it can be changed.
        • Wbankard
          • Apr 2016
          • 18
          Re: MPC305SPF
          Toner not set!!!
          I can understand the bent pins on the board, DUMB WAY TO MAKE CONTACT, but how do I get to the pumps to fix them? got a book on order. EU used third party toner not OEM and then used canned air to clean out the excess yellow toner.
          Stripped it down as far as I could with out a road map and vacuumed. The one problem is that the yellow toner cartridge will not close up when removing.
          • Zeldaman
            • Mar 2011
            • 946
            • Polarbear
              • Feb 2012
              • 1070
              Re: MPC305SPF
              +1 on the bent pins!
              Press the GREEN button!!
              • Wbankard
                • Apr 2016
                • 18
                Re: MPC305SPF
                Interesting the part Number on the board is D1175161A, update / mod ?
                • Zeldaman
                  • Mar 2011
                  • 946
                  • Wbankard
                    • Apr 2016
                    • 18
                    Re: MPC305SPF
                    I was wondering if we were talking about the same thing. The board I removed was located across all four toner supply pumps. Each one has a pin guide and three ribbon contacts for each pump area. A couple are bent not broke. That board has a different part number than you provided. The one on the board is D117 5161A, but in the manual it is D117 5160. Where can I get one ?? I found two places ones $119.00 the other is $190.00 big difference for the same thing. So the new number is D117 5162 ?
