Df3010 adjust?
  • mrfuser
    • 1622
    Df3010 adjust?
    Client complains that the df3010 on an mpc4500 is not scanning page size correctly. Is there an adjustment we can do?
    thanks all!
  • Polarbear
    • Feb 2012
    • 1070
    Re: Df3010 adjust?
    thanks all!
    Can you post a sample of what is happening? We need a little more detail than what you are supplying.
    Press the GREEN button!!
    • mrfuser
      • 1622
      Re: Df3010 adjust?
      Client scans letter size and it asks for 11 x 15. Not even standard size
      • jfbar1
        • 53
        Re: Df3010 adjust?
        Most common problem is dust on the size sensors located on the original tray (3 "holes") running across the right side of it. I was in the habit of cleaning them off every call.
        Worse case is a loose connection under the tray to those same sensors. cover on back side can be removed to check.
        Good luck
          • 37553
          Re: Df3010 adjust?
          Another frequent problem that I encounter is that the user has placed something on the feed table that is covering the length sensor(s). Also check for a bad sensor or a loose connection on the sensor wiring.
