I've decided I hate Macs!!
  • Leebs14
    • Feb 2014
    • 457
    So asked to install a MPC2551 with the Postscript option fitted to a company who only use macs.
    Install machine, connect to router use DHCP to pick up network settings all ok. Customer can see the MPC2551 via Bonjour on his Mac, downloaded and installed the El Capitan driver, Mac configures everything automatically and we are done.
    Does it print? Of course it doesn't the data light on the copier flashes, the Mac says it's connected but nothing.
    So we try to print using IPP, Jet Direct etc etc and nothing prints, data light flashes but nothing prints.
    Network print out say postscript is enabled, we can view the machines webpage but it won't print?!!
    Any help appreciated
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: I've decided I hate Macs!!
    First make sure that user authentication has been disabled, or that the Printer restriction has been turned off.
    Install v2.2.0.0 driver, when adding the printer use direct IP address and protocol LDP. For some models (03s) I've had to enter the queue print, for it to print, this may not be needed but it doesn't hurt to try.
    If the device has been recognised, the driver should be automatically selected, if it still says Generic, then the Interface Settings may be incorrect, the driver wasn't installed correctly, or the Add Printer window was left open as the driver was being installed.
    • Leebs14
      • Feb 2014
      • 457
      If by user authentication you mean user codes/login then yes that's switched off
      Click the + sign to add s printer, it recognises the Ricoh machine, click the IPP tab enter the IP address click on LPD Deamon, the Mac automatically selects the driver we downloaded (there was only 1 driver for El Capitan on the Ricoh mpc2551 download page) click ok it loads everything closes the add printer page but won't print?? I didn't try adding the word print in the queue.
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Try checking the copier's print error log, see if there are any errors there. Also, try clearing the Printer Application in SP5-801, in case there is a stuck print job in memory.
        You can test for stuck print job, but going to Printer SP > Test Page, as it uses the same memory.
        Is the PS firmware up to date?
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Try printing from a Windows machine (with the PostScript driver, of course) to see if it works. If you have to, you may need to use your notebook with a crossover (although most newer computers will auto-sense, meaning you can use a normal patch cable). You will most likely need to change the IP to a static address, although the machine may hold the IP assigned by DHCP long enough to be usable.
          I've seen it where the PostScript card was bad, the wrong one, or had been improperly removed from another machine, messing up the license.
          Also. as Ruben mentioned. try using "lp" (that's lower case "ell-pee") as the queue name. I remember that on the older models the default queue name did not work. I do not know if that has changed.
            • 37556
            User Tolls - System Settings - Interface Settings - Print List.
            If there are any entries for any Access Control Range, you need to clear those through WIM or by using SP 5801-011 NCS.
            Also as Rubin said personally confirm that User Authentication is set to off. I have seen it on with only printer being restricted.
            • rthonpm
              • Aug 2007
              • 2859
              Try adding the printer address as: lpd://IP Address/lp or lpd://IP Address/print (lp was what most past Ricoh devices used as their LPR queue name). It does sound like there's some kind of user restriction on the machine though.
              • Leebs14
                • Feb 2014
                • 457
                Machine prints fine from a PC using standard TCP/IP Address port.
                • keithxxiii
                  Just a tech
                  • Nov 2014
                  • 471
                  Adjust the network security level to 0 (from user tools ->systems settings ->administrator tools ->network security)
                  Aye! Cut the crap
                  • Leebs14
                    • Feb 2014
                    • 457
                    Update...
                    All user authentication definitely off
                    Network security set to 0
                    Tried LPD with all settings mentioned
                    Tried IPP
                    Tried Jet direct
                    Green data light on machine flashes but Nothing prints
                    Connect laptop and using pcl6 driver it prints fine
                    Installed PS driver on laptop and it doesn't print
                    I'm guessing the PS card is faulty??
                    • copier tech
                      • 8192
                      Is it a brand new PS card? & what type is it?
                      • Leebs14
                        • Feb 2014
                        • 457
                        No idea as it was in the machine already, it's recognised by the machine as its shown on the config page print out when fitted
                        PS3 type 2550
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3944
                          Just because the machine recognizes it doesn't mean it's good.
                          The fact that a Windows based notebook can't print either means it's not a Mac problem.
                          Try this: From the PC, LPR a PDF fie to it (make sire it's small, you don't need a big test), by going to a command prompt and typing: "lpr -S <ip address of copier> -P lp c:\test,pdf". For example "lpr -S 192.168.1.10 -P lp c:\my-ps-test.pdf".
                          The S and P are case sensitive, and you may need to add the LPR feature to Windows.
                          That will keep a bunch of variables out of the equation, especially anything to do with driver or platforms.
                          My hunch is it will fail, and you have a bad PS card.
                            • 37556
                            Which SD card slot is the PS3 SD card inserted in? For proper operation it need to be in the top slot, Slot 1, Slot 2 is only for firmware updates and the VM card. If there is another card in slot 1, you will have to use Move Exec to copy the contents of that card to the PS3 card.
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              Also worth noting that due to licensing, other apps (not VM) can be merged onto the PS card, but the PS card can't be moved to another.
                              Some years ago we had a tech kill a PS card by attempting to merge it to another. The boss was NOT happy.
