MP201 Windows 10 scan to folder
  • Dark Helmet
    • May 2009
    • 835
    Hey guys, has any body been able to make a MP 201 scan to windows 10 folder?
    Ive done all my tricks i normally do for Windows 7 and i have had no luck with this thing.
    I know the older copiers don't support SMB 3.0 or something along those lines and they can't scan but MP201 is a current model. I checked TRSC site and the newest firmware is from 2014 for NetworkDocBox.
    Any body else had any luck?
  • rthonpm
    • Aug 2007
    • 2848
    Re: MP201 Windows 10 scan to folder
    You want the Network Support firmware, not NetDocBox. The 201 should have an update for Windows 8/Server 2012, which were the first versions of Windows to use SMB 3. Go ahead and update everything and try setting up everything again.
    • Dark Helmet
      • May 2009
      • 835
      I went back to the TRSC and found a special firmware that takes care of this issue.
      D115
      2/25/2013
      The following SMB-based GW functions will work with Windows 8 and Windows Server 2012 with this firmware.
      D115
      2/25/2013
      If you are logged into TRSC those links should download the proper file.
      Thanks!
      • mikedci
        • Jul 2010
        • 227
        fwiw latest network firmware is
        D069_D115_NCS_v907_SDcard
        http://rfg-esource.ricoh-usa.com/ora.../rfg037022.zip
        there is also newer custom network firmware for the browser https issue
        • afterhours
          • Mar 2017
          • 152
          Originally posted by mikedci
          I realize this is a very old Thread, but is there any way that you can provide this firmware? Id be willing to purchase firmware that would allow a Ricoh 201 to scan to windows 10.
          Im a Loser Baby!!!
            • 37324
            I would advise that you start a new thread. Many of us old farts who would have the firmware don't appreciate grave robbers.
            • anothertech
              • 1760
              If you are willing to pay for the firmware, place a call on the machine and a Ricoh tech will come and update it.
                • 29901
                Just either use scan to email or scan via ftp using filezilla server
                • Tatteous
                  • May 2017
                  • 24
                  All firmware needs to be current especially NCS.
                  Win 10 has more steps. Try this..
                  • sandmanmac
                    • 3979
                    You're quoting the guy that started this thread over 2 years ago, and it was resolved in short order, and he returned to update us that it was a firmware issue.
                    Input and Advice is appreciated, but please take the time to read suggestions and solutions before weighing in. You'll actually be amazed at how much you learn yourself.
                    • sergo
                      Hi all. Have the same problem.
                      I don`t have access to ricoh official site.
                      Help please, need firmware for mp 201 spf with network version 9.07.
                      Thanks.
                        Thanks.
                        did you READ all the posts in the OLD (dead) thread?
                        there were even LINKS posted to the FW.
                        • Malins
                          • Dec 2019
                          • 4
                          And how to download 9.07 if all links do not work? There is only one working on 9.06.
                          • Malins
                            • Dec 2019
                            • 4
                            Сам нашёл, спасибо.
                            Работает на MP 201 и MP 171.
                            Ricoh firmware
                            Ссылка на NIB 9.07
                            Так же есть полный набор прошивок.
                            • anothertech
                              • 1760
                              Сам нашёл, спасибо.
                              Ricoh firmware
                              Ссылка на NIB 9.07
                              Seriously? You are going to post in Russian? Come on comrade!
