MP 171 door open problems
  • tibbs
    • Aug 2008
    • 225
    Good day friends, am having some problems in the field with some MP 171. They have a door open problem that I cannot seem to get to the bottom of. The latches are not broken but the right door is just not closing properly
    Any suggestions will be welcomed.
  • sandmanmac
    • 3990
    Re: MP 171 door open problems
    Actuator gets bent inside right cover. use a small screwdriver to bend it out slightly, for better contact. If that doesn't work, obviously the switch is bad.
    • mongo
      • Jul 2009
      • 55
      Before you go bending things check to see if the plastic tits on the top left side of the door is broken. If not I like two layers of electrical tape cut to size place on the silver actuator instead of bending it, but that my preference because when you bend something it will bend back over time. Mongo
      • jfbar1
        • Oct 2008
        • 53
        It seems to be a common issue with these. The "best" fix is to replace the side door cover. It never really looks bent, but it DOES resolve the problem. Its really NOT too bad to take off the transfer unit and couple of guides. I wouldn't recommend trying to find a used one cause it may be deformed as well.
        • Polarbear
          • Feb 2012
          • 1070
          Tibbs
          Some questions for you:
          If you say the door is not closing properly - what do you mean?
          Does it not shut so that it is flush with the frame? Or does it not close at all?
          Was it so when you got there, or did you discover this after working on the machine?
          Any chance you have photos of the situation you could post?
          Press the GREEN button!!
