Overall Impression of the MP4000/5000
  • Jomama46
    • 2900
    #16
    Sgt Snacks: You know what I've been considering? Vac all the toner/dev out of the machine, whack some B079 in there with the old type Toner and see what that does, certainly worked better in the older machines."
    Thought of this myself but havent tried it yet. Just dont forget you have to change the toner drive motor also so it will fit the B079 bottle.
    sigpic
    A+; Network +; PDI+
    • paulg
      • Jun 2007
      • 278
      #17
      Originally posted by FRIDGEMAGNET
      I had 3 x 7950 Penguins on my area 6 years ago and they regularly went 300k between calls - PM to PM - much better than the digital equivalent 650.
      Better than 650 maybe but hardly a major upgrade on the 7650.
      I know many failed on setup and needed parts and alsorts before being installed.
      • TonerMunkeh
        Professional Moron
        • 3865
        #18
        You'll never guess what.... it's exactly the same bottle. Same colour, same drive lugs, everything. Only difference is it says MP4500 on it. That's why we've had such a problem with customers putting the wrong toner in the machines.
        Hit it.
        • SGT_Snacks-64
          • Oct 2007
          • 157
          #19
          Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
          Asus P5E-VM HDMI
          4GB (2x 2GB) Corsair XMS Xpert II RAM
          ATi Radeon 4870 512MB GFX Card
          2x 74GB WD Raptor Sata HDD (RAID 0)
          500GB Seagate Barracuda Sata II HDD
          500GB Hitachi Sata II HDD
          600W500att OCZ PSU
          -TOTAL HDD SPACE 1148GB-
          • Jomama46
            • 2900
            #20
            I stand corrected, right after the B079 they changed the toner(to polymerized) and therefore the toner motor.
            sigpic
            A+; Network +; PDI+
            • slot
              • Jul 2008
              • 341
              #21
              After you srub up the mag roller always reset the bias in sp2001 back to default and then run a process controle this always brings the c+q back up. also has anyone had any D/F jamming probs on this box
              • SGT_Snacks-64
                • Oct 2007
                • 157
                #22
                I've had DF jamming problems, but nothing really out the ordinary. Either something caught in the paper path, the rollers and belt worn or the actual DF out of position, which you can push back into position
                Asus P5E-VM HDMI
                600W500att OCZ PSU
                • cobiray
                  Passing Duplication Xpert
                  • Mar 2008
                  • 1199
                  #23
                  I've been contemplating the B079 supplies also. I'm just wondering if the toner will have problems fusing at the lower temps. I suppose they could be bumped up a tad...
                  If you are having adf jams, check the non reflector on the exit side of the scanning glass. The easiest way to get at it is through the top.
                  • unisys12
                    • 489
                    #24
                    Ok, but I don't about you guys, but I have seen this happen (toner on the mag roller, throwing everything off, then causing toner to spew everywhere) on the B003 series as well. This family was the first time I had seen happen to this level. This family, overall, has always had problem with drum coating, but something happened in the B003 that took it to a whole new level. And I think with each revision, they have tried to solve the problem, only took it furthur in the other direction.
                    This is my opinion, merely based on my observations, so I don't think it's just the toner causing the problem. It has to be a combination of things and for me, I personally lump software in there as the main culprit. Combine that with poorly matched toner or even a sensor and you have yourself a serious problem.
                    Now, sticking with SGT's idea... I would rather put some B003 toner and dev in one and see what happens. I don't know... I think the TD sensor changed on the this family or was it the B079? That might affect things in a bad way, so... Then again, hell... it might help! Who knows?
                    sigpic
                    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
                    • cobiray
                      • Mar 2008
                      • 1199
                      #25
                      If I recall, the td sensor for the B079 is the same for the B291 and the D009. That would lead me to believe that on paper the B079 developer could be used in the newer dev units.
                      My opinion is that the whole family of machines are pukers, but the new (dare I say improved) toner formula is worse by far. With the older machines, I had been able to get reliable performance by thoroughly cleaning the units during PM's. The newer (B291 and D009) units are far worse and cleaning doesn't help. Rarely have I had any go to 150k with out a PCQ service call. I can honestly only come up with one unit out of maybe 60-75. I feel its a bad to worse situation.
                      • E Winter
                        #26
                        It's a mess that ricoh kept the toner/dev from the previous MP3500/4500 series because this was a mess, too. And the technical bulletin is a joke because the so called "final solution" does reduce the toner concentration to an extremely low level to avoid clogged DV rollers. On the one hand many customers are not happy with the black reproduction an on the other one, even this "solution" doen't bring back the scheduled PM cycle on my machines. At least the new PCU/DV-Unit design is good because it can collect much toner spilling before it's crawling through the machine
                        • slot
                          • Jul 2008
                          • 341
                          #27
                          Here is what i think
                          The main problem is the toner melting at a lower temp but the m/c speed has increased .With the B003 m/c the problem was often solved by changing the mag roller or the pcu i suspect that the gape between the drum and the mag roller is too small this causese friction and heats up the toner as it passes the drum thuse melting it to the mag roller. the answer would be to add somthing to the dev unit to take the heat away or increase the drum/magroller gape . this is only my idea but it seems logical
                          • E Winter
                            #28
                            My guess is that only some changings at the toner/dev itself may solve this problems. Friction does also occure at a much higher level during mixing inside the dev station and especially at the doctor-blade gap - hard to avoid this.
                            • ZeusGT
                              • 271
                              #29
                              We do have a handfull out here and they are nothing but trouble in this end too. I've had one with less than 100 copies on it blow the fuser clean out. We installed 6 in a plant and EVERY last one of them broke the first day upon delivery... Junk is exactly what they are. I would hope that Ricoh wouldn't let this continue or maybe they will and keep buying other businesses and deny raises to their employees for a better profit margin
                              We have several of them sitting in the shop waiting for repairs that are barely used.... Luckily the sales department haven't been selling many of these except for the City contracts and "the big shipping company with a lot of airplanes" can't name names...
                              I don't care for them....
                              CompTia A+ Certified
                              CompTia Net+ Certified
                              CompTia Server+ Certified
                              CompTia Project+ Certified
                              OP Scanshare Certified
                              • SGT_Snacks-64
                                • Oct 2007
                                • 157
                                #30
                                If anyone has one in a workshop, not being used, speak with your service manager and see if he'll let you try B079 developer What's the worst that could happen?
                                Asus P5E-VM HDMI
                                600W500att OCZ PSU
