Another technical bulletin has been posted a few days ago. It describes almost the same "workaround" well known from the last bulletin (lower the toner concentration via SP edits to the absolute minimum) - besides one additional info:
SP2001-001 (charge bias) - add 100 to the current value
But all in all it's kind of nonsense or a bad joke what Ricoh says regarding what factors causes the problems:
- low enviroment temperature
- high print volume
- doing many 1:1 copy jobs
- paper dust in the waste toner process
- printjobs with a high black coverage
Eeerrrrm..I had trouble in very different and mostly regular enviroments so it's an absolute bullshit to try to assign the blame to these factors while not to mention that this is a 100% toner/dev issue.
At least the bulletin does mentioned that they are still working on a "so called" final solution. Maybe kind of "just don't use this machine for any print and copy jobs"
- high print volume
