Ricoh 2035
  • tcypy1961
    • 773
    [Jamming] Ricoh 2035
    what does the pf deck have to do with Jam 060 code??? this happens with legal paper in either pf drawer; however letter LEF works with no paper stoppage; which is what's happening paper is not getting hung on anything just stopping; can only get the copier to stop on multiple run not on single copy run.
    Thanks!!!
  • Polarbear
    • Feb 2012
    • 1070
    Re: Ricoh 2035
    Thanks!!!
    Hi tcypy
    If I understand your question correctly: single copies don't cause the jam but multiple copies do?
    Is the machine set to auto-detect paper size per tray or is it set to a specific type?
    It sounds like it has to do with paper timing - which makes me think it has to do with paper size detection.
    Press the GREEN button!!
      • 37556
      Re: Ricoh 2035
      Jam 060 is a trail edge jam at vertical transport sensor 3. Check the correct paper size. If the size is displayed correctly on the display, then replace transport sensor 3.
