Lanier LD425B (aficio MP2550) with J001 message which I don't find in manual
  • axyun
    • Aug 2007
    • 1323
    custromer called yesterday with J001 message. I looked in operator and SM and don't see this and would be very grateful fioe some assistance before going. I will cklean out sensors in adf etc and check for small pieces of paper after questioning customer when I get there. Frank/ActionPhotocopy
    • 37491
    Re: Lanier LD425B (aficio MP2550) with J001 message which I don't find in manual
    J001 is a jam found at power on or when a door is closed. If it occurs during operation, it is usually a door switch. If the machine has a finisher, not the internal, replace the cover switches in the bridge unit, common problem for years.
    • axyun
      • Aug 2007
      • 1323
      Thanks Tim. Wondering why I was not seeing j codes in manuals . Frank
      • axyun
        • Aug 2007
        • 1323
        When I got to customer's office the displayed actually mentioned doc feeder jam. None there but after cleaning oyt sensor and rollers all is good. Thanks much. Frank
