Blank Copy MP171SPF
  • +ve charge
    • May 2008
    • 87
    Blank Copy MP171SPF
    Hi.. Just finished servicing a MP171SPF (no replacements) just a general cleaning and vacuuming as the toner had spilt inside the machine. Now there is no print/copy. Even the "counter copy (from engine)" is blank. Tried changing PCU's from different machines but no luck. Pls give me some suggestions. Thanks in advance.
  • Zeldaman
    • Mar 2011
    • 946
    • +ve charge
      • May 2008
      • 87
      Re: Blank Copy MP171SPF
      Thank you for your response Zelderman, I checked the cassette earth plate and cleaned the grease on the drum shaft but still same 'blank copy' issue. Greeting to U too.
      • Polarbear
        • Feb 2012
        • 1070
        Hi
        Stupid suggestion - but here goes:
        You didn't leave anything (like a cloth) in the cavity to the left of the toner hopper? This will effectively stop the laser light from reaching the drum = blank copy.
        Else I would suggest starting a copy then stop the machine midway to see if there is any image on the drum - if so it is a transfer issue (check the right door).
        If blank then there is an issue between laser and drum.
        Press the GREEN button!!
          • 37508
          Maybe anithere stupid question but is there a toner bottle in the machine? Some of these entry level machines have a lever at the back of the toner hopper that kills the laser is there is no bottle in the tray.
          • +ve charge
            • May 2008
            • 87
            Thank you for your responses. Whilst cleaning the toner spill inside the machine a thin film of toner had deposited onto the laser curved lens After this was cleaned everything was ok. Its yr "apparent" stupid reply's that helped . Really appreciate this.
