MPC 305 having SC 544
  • DP1
    • May 2016
    • 7
    Hi every one in this fantastic Global Group,
    I am Ricoh Eng, Got MPC-305 given me SC 544, ( over heat ) manual says to change BICU board or Fuser control Board,
    Thermopile,themostate all ok.Fuser sleve also good condition .what can i do next
  • copier tech
    • 8161
    Re: MPC 305 having SC 544
    Have you tried a SP5810-002 reset?
    • DP1
      • May 2016
      • 7
      I did,even fuser not getting ideal mode when i switch on machine. straightway getting SC544
      • mrwho
        Major Asshole!
        • 4299
        I'd try a new fuser or a used one from a known working equipment before anything else.
        Mascan42
        Ibid
        • DP1
          • May 2016
          • 7
          Thank you, will try this new fuser, i will post the result.
          • copier tech
            • 8161
            Yes I would try another fuser, reset with SP5810-02 power off then open the right door & power on if you get SC544 before closing the right door i'd suspect BICU
            • DP1
              • May 2016
              • 7
              Thanks,
              • DP1
                • May 2016
                • 7
                Problem fix by putting New Fuser unit,
