MPC305 j003
  • copier tech
    • 8144
    MPC305 j003
    Hi all,
    I've got a few of these out & any that are doing moderate volume seen to jam frequently from tray one J003 all had new feed roller & sep pads. Im at a bit of a loss!
    Also cant seem to find an output check to run the feed motor!?
  • HDSB
    Field Tech
    • Feb 2013
    • 64
    Re: MPC305 j003
    Hi all,
    We have loads of these out there that had constant 4th vertical transport jams.
    Add more tension to the Sep pad spring and it's fixed.
    Seemed to feed the next sheet too far and flag a jam.
    • copier tech
      • 8144
      Re: MPC305 j003
      OK thanks, I've ordered a new paper tray for it in the hope that will fix the issue!
      Have you had to change the feed clutches or motors??
      • HDSB
        Field Tech
        • Feb 2013
        • 64
        Re: MPC305 j003
        none at all.
