Ricoh MP9002 Sc144 error
  • mdfurqan2012
    • 194
    Dear All,
    I have mp9002sp when we switch on or active from energy saving position it occurs sc144-00 and after turn off and on the machine on 2 to 3 times machine becomes ready but often generates sc144-00 again during job.
    I re punched connectors of IPU board CCD Unit SBU board and after that machine becomes OK for some time but now again sc144-00 occurs I re punched connector but problem still remains.
    Kindly Guide me
    I am thankfull to you
  • sandmanmac
    • 3983
    Re: Ricoh MP9002 Sc144 error
    This is your 3rd post on this topic! Except you seem confused about the model #
    http://www.copytechnet.com/forums/ri...c144-00-a.html
    http://www.copytechnet.com/forums/ri...144-error.html
    • mdfurqan2012
      • 194
      I am not confused actual I need help yo resolve that issue.
      Please help me
      • developer dumper
        • 21
        replace the Lens\Sbu assembly
        • mdfurqan2012
          • 194
          I replace sbu assembly but issue still remains
          When start machine no initial lamp movement. this problem becomes still now.
          Plz guide me I am really thankful to you
          • mdfurqan2012
            • 194
            Now I replace sbu harness but issue still there machine generates sc144.
            Kindly guide me.
            • tufbnme
              • 493
              There are no bulletins on the issue but this may help.
              SC144
              SBU transmission error
              • After the SBU switches on, the BCU detects one of the following conditions on the SBU:
              • 1 s after power on, the SYDO signal does not go high, even after 1 retry.
              • 1 s after power on, the SYDO signal goes high, but the SBU ID could not be read after 3 attempts.
              • SBU defective
              • SIOB defective
              • BCU defective
              • Harness between the SBU - SIOB is disconnected
              • Harness between the SIOB - BCU is disconnected
              • Harness between the SIOB - PSU is disconnected
              • tufbnme
                • 493
                Also, check and update the firmware, solves a lot of issues.
                • mdfurqan2012
                  • 194
                  SC144
                  • SBU defective
                  • SIOB defective
                  • BCU defective
                  Dear I replaced sbu I replaced harness and check connectivity of harnesses by multi meter, I add one more thing that sc144 is not still. Machine generates sc144 occasionally sometimes machine works perfectly whole day and sc144 occurs in evening.
                  • Counsel
                    • Aug 2011
                    • 529
                    If you replace the assembly already and both harnesses i would check the PCB-SIOB, firmware history does not show any fixes correcting sc144s but it wouldnt hurt to update that as well.
